Inventor assembly constraints - show constraints only for the part being assembled
Message 1 of 21
Hello
I'm new here, trying to learn Inventor.
One thing I noticed in the assemblies and I don't understand why Inventor does this is to show all constraints from all parts under one part.
It shows the assembly constraints for the part itself and then it shows all the constraints from all the other parts that are assembled onto that part.
For example in the picture I attached three of the mates are used to assemble the spacer onto a plate. The rest of constraints that show up are from other parts assembled onto the spacer.
Why does inventor work like that?
Why not show only the three constraints that are used to assemble the part?
And OK let's say it's a functionality of Inventor, but who uses this "feature". If you have like 10 parts assembled onto the spacer all constraints from all 10 parts will show under the spacer. And if you want to modify the way the spacer is assembled you have to go thru all those constraints to see which ones are just for the spacer and not for all the children's.
I don't understand why its a good thing to go thru like 30 constraints to find the ones you want to modify.
Or is there a setting to see just the constraints for each part ?
Replies (20)
Message 21 of 21
johnsonshiue
Hi Nico,
We are indeed working on feature grouping (part-level browser folders). If you are interested, please sign up Inventor Feedback Community (https://autode.sk/InventorBeta) and try it on our latest internal build.
Many thanks!
Software Test Engineer
