Thank you all for suggestions, here is what happens, will answer separately:
Mark
- I've tried "Refresh" as in article and didn't change anything
- I don't have Older Version folder as I clean it often; I may ask the user who is in charge of this project
Kenny
- I tried to open from Vault within Inventor
- I tried "Get" the files from vault and then open straight in Inventor
- I opened the files logged in or out of Vault, same result
- by default, when Getting files from Vault they are read only; first thing I remove the read only check in windows explorer, then open the file in Inventor
- I dont have libraries components
- I can check them out from Vault but that doesnt help; in the end I have to undo the check out as I cannot update with newer versions from Inventor (because I cannot save any changes)
Brendan
- you are correct, I tried opening the files logged or out of Vault
John (he emailed me privately)
- see above
- your suggestion about zipping was a good idea
I tried what John mentioned (Pack and Go from Vault) and was not able to "extract" the files out of Vault... it just doesnt want to create a zip/unzip folder; see attached the new error I'm getting. That could conclude that somehow Vault damaged the last Inventor assembly version.
My only viable solution that worked is to get the previous version from Vault; I was able to save the changes. Also, a Pack and Go from Vault of that previous version worked nicely.
The question becomes: how to fix a version in Vault of an Inventor file?
I assume this should be shared to the Vault Forum.
Thank you all again for your support, will keep you posted if I get feedback.
radu
