Inventor API Save as JPEG with Transparent Background
I have been scouring the forum and API help section to see if there is a command similar to "SaveAsBitmapWithOptions" for JPEG, but haven't found anything.  What I want to be able to do is shown in the code, but I need to export to JPEG for my cloud database. I can change the file type to .JPG, but I lose the ability to make the background transparent. Is there a command to do this, or a workaround to convert the exported .BMP to .JPG?
Public Sub ExportToJPG()
    ' Get the active view.
    Dim oView As View
    Set oView = ThisApplication.ActiveView
 'Create a new NameValueMap Object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap '.TransientObjects.CreateNameValueMap
    oOptions.Value("TransparentBackground") = True
    Call oView.SaveAsBitmapWithOptions("C:\Temp\TestB.bmp", 200, 150, oOptions)
End Sub
mcgyvr
JPEG files don't support transparent backgrounds..
PNG will..
Curtis_Waguespack
Hi @Anonymous
Firstly API related questions are better handled  on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Secondly, I don't think JPG supports transparent backgrounds, so if you save a file that has a transparent background to JPG the transparency is lost and you just get a white background.
So would a JPG with a white back ground work?
I hope this helps.
Curtis
Didn't realize JPEG did not support transparent background.  .PNG will work for my application. Thanks for the help!
