Inventor API - Change the Selection Filter in Part Environments
Khoa_NguyenDang
Khoa_NguyenDang
Hi all guys
Have a nice day first
I am finding a way to change the Select Filter in Part Environment with API Code (VBA, C#) (like in the picture)
Does anybody have experience with access to it and change the select filter?
If anyone knows about it, hope you can help me
Thank you so much
dutt.thakar
@Khoa_NguyenDang
Please post your API questions to Inventor Customization forum.
See if this helps.
If you are using Pick method you can change selection filter there from SelectionFilterEnum object. So Your code will look something like this.
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face")
See this link which has the list of different Enumerators that can be used in selection filter for changing the selection  type.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-0CF01252-5F21-4329-AFC2-E1B1277DA3BA
Hope this is helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Khoa_NguyenDang
hi @dutt.thakar
Thank you for your reply
I know about the Pick method in Inventor, it can help to change the select filter
But out of Pick method, do you have any method else to change
I just want to change, do not want use Pick Method
dutt.thakar
@Khoa_NguyenDang
Ok, If you want to change the selection filter in general for the Part document, Try this code
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
oDoc.SelectionPriority = SelectionPriorityEnum.kBodySelectionPriority
 In this case, SelectionPriorityEnum will work, check this out and you will be able to see different enum values that will be used for different selection type. You can use the same enumerator in Part, Assembly, Drawing, and Presentation document, you just need to change the document type.
Hope this will be helpful.
Dutt Thakar
LinkedIn
Khoa_NguyenDang
@dutt.thakar
Yeah! That right what I need
Thank you so much @dutt.thakar
One more thing, hope you know about this
I want to create a feature  (thicken) when Part in the Edit mode of Assembly by API
I used Document oDoc = _invApp.ActiveEditDocument;
But at the time create Thicken Feature, the error occur
Do I miss to declare any item?
