I am having an issue with my Inventor 2010 and Trueview 2015. Whenever I go to edit a drawing in Inventor by double clicking or right-clicking and selecting Edit, it opens in Trueview. I do not want this to open in Trueview, but AutoCad Mechanical instead.
I am sure there is an easy way to fix this but I can't seem to figure it out. FYI I do NOT want to uninstall trueview 2015.
Thanks.
Solved by blair. Go to Solution.
You need to change your Windows setting, looks like you installed TrueView after Acad, so Windows has set the association for that file tyep extension to TrueView.
You need to open Windows Explorer, RMB on a DWG file and select the "Open With", then select the "Choose Default Program" and change it to Acad.
