J.D.,
I am at wit's end. I still don't have a solution. I also need to add one more descriptive constraint of my own.... The part is designed to be cylindrical and concentric. The end plane of the extrusion needs to be arc-shaped (w/ same radius as a circle of the same radius), yet the sides of the extrusion need to be perpendicular to the drawing plane.
Attached is the file and the work that I have done so far. I don't understand how you can tell what I've tried, so I've added my description:
- I've tried extruding from the drawing plane but I can't get the end plane of the extrusion to have a radius.
- I tried extruding from the face of the cylinder (directly under the extrusion feature) by picking the starting point on the cylinder face and giving a depth of extrusion, but the end plane of the extrusion had the same radius as the cylinder from which it started.
- I tried to make a circle on the XZ plane (in order to define the radius of the extrusion's end plane), from the TOP view, but the program wouldn't even allow me to make a simple circle.
Here's another problem I ran into...
- The feature can't be extruded in both directions. Otherwise, one of the features will have a mirror image of what it is supposed to be. There may be an easier way, but I was forced to draw the feature two times. The problem was: when I rotated the part to draw on the opposing face I could see the lines for the feature from the opposing face. Once I draw lines on top of other lines, I am unable to differentiate and/or select either set of lines.
Please help,
David
1) I tried extruding from the drawing plane but the geometry of the end of the extrusion is not correct
