Hey all. So I'm having a problem with Inventor 2024 were it just crashes after startup and I either start a new project, try to go to the options screen or load anything else from inside Inventor. The Error I'm Getting:
Application: Inventor.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: FwSrv.dll
Exception Address: 0x00007ffda24768d0
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 3e
Now yes there is a solution on these forums to this exact error and no that solution did nothing for me. Enabling the High DPI Check Boxes in the compatibility window of the program does absolutely zero to solve the problem.
Link copied
