Inventor 2023 - Bug BOM Sorting
BLA_fpineda
BLA_fpineda
Since I migrated to Inventor 2023 I have this problem.
I keep updated to Inventor 2023.1.1 release.
Every time I open the BOM menu the secondary and third sort filters is fixed as the last column of the BOM.
If I set it up with Nothing, the sort filter remains in Nothing.
But if I set it up with other column, the sort filter allways applies the last column of the BOM.
Someone with the same problem?
Could someone solve the problem?
CGBenner
@BLA_fpineda
Hi, can you please share some screenshots of what you are seeing?  I'm having a hard time picturing what you are describing.  Thanks in advance.  🙂
Chris Benner
BLA_fpineda
@CGBenner I uploaded the image on the top.
johnsonshiue
Hi! Yes, this is a known issue, reported as INVGEN-62446. Essentially, sorting multiple Custom iProperties in the BOM dialog is broken. This is a regression from Inventor 2022. The current status shows the fix targets 2023.3 update (too late for 2023.2 update unfortunately. I will work with the project team to see if it can get fixed sooner.
Many thanks!
Software Test Engineer
BLA_fpineda
@johnsonshiue Thank you for the info.
Let me say that I used the latest version of 2022 until now and never saw this problem.
This is not your business, but let me say something:
I think that this kind of bugs should be a priority for Inventor developers and is unacceptable that could be fixed in two releases.
It supposes that when we upgrade to a new release we should have upgrades, no downgrades. We are paying a lot of money for this software!
johnsonshiue
Hi! I think this particular bug go into 2022 updates also. You may want to uninstall the update to revert the behavior for now. This is absolutely wrong that a defect like this slips through the crack. It should not have happened in the first place. I am very sorry.
Many thanks!
BLA_fpineda
If you are a developer you should know that when you migrate files to 2023 and all the configuration files, libraries, etc. You cannot return to previous version...
