- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As the title suggests, I'm having an issue in Inventor 2023.4 in the .idw environment, where I've created a 2d sketch of the centerline of a coil in the top-view, and Inventor refuses to attach a dimension to it. The centerline was created by projecting both the coil's O.D. and I.D., creating a dimension between those to get the overall width, and then dimensioning from the inside to the centerline and using the overall width/2 as the value for the centerline dimension in the sketch.
Is there a way to generate a centerline dimension in the drawing view of the coil's centerline?
Intel Core i7-7700K CPU @ 3.60GHz
64GB RAM
Windows 10 Professional 64-Bit, Version 22H2 - OS Build 19045.5371
Autodesk Inventor Professional 64-Bit Version 2025.2.1 - Build 293
64GB RAM
