Message 1 of 13
- Mute
- Permalink
- Report
I have a skeleton.ipt with sketches to drive parts (geometry and position) in an assembly. I want to use model states to select model states in the parts/skeleton (with derived component function). When you use derived component in a part, you cannot connect the model state of the part with the model state of the derived component (skeleton) I attached a simple example for a cylinder with 2 positions (open/close) . (Note: In general the skeleton will drive later different part sizes and LODs, so it is not possible to use constraints). Is there a workaround?
Thanks, Norman
