After starting the program and clicking the button:
The program hangs - process kill required.
The following solution helps one time:
Launching the File> Management> Projects panel
Indication of the path to MT_Vault again (file 😧 \ Vault Working \ MT_Vault.ipj) via PPM> Browse:
After clicking "Done", starting the "New" window is possible.
I must select the path again after restarting Inventor. Otherwise the program freezes again.
All Inventor 2022 uninstalled, rebooted the computer and reinstalled Inventor 2022 - this did NOT fix the problem.
I am asking for help in finding a solution.
OS: Windows 11 Business with Azure Active Directory and OneDrive sync (Documents folder on OneDrive)
Inventor 2022:
Try this fix that worked for a few other people and honestly is quick and easy to test:
1- Go to Tools (tab) > Application Options > General (tab) > My Home > check "Show my Home on Startup";
2- Close Inventor;
3- Open Inventor and add a shortcut to your Templates folder (the path where they are located in the server):
This might work if your Inventor is struggling to keep the access into that folder, and Inventor is getting blocked.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Are you aware that there are several updates for Inventor 2022? AFAIK the current version is 2022.2.2 (Build 287).
(But i don't know if these apply to your problem.)
Jürgen Palme
Hi! I don't believe this is an install issue. More than likely, it has something to do with how the project was set up. First thing to check. Go to Project settings -> Folder Options -> Design Data. Does Inventor have the privilege to read and write to the folder?
Try running Inventor as Admin and also clean up %temp%.
Many thanks!
