- Mute
- Permalink
- Report
Hey everyone,
I just downloaded Inventor 2022 yesterday. I just created a sketch on a face, and I have autoproject turned on, so everything on the face is projected into the sketch. Most of the projected features I don't need, so I usually box select and either delete or make them construction lines. As I started to do a box select (click, drag diagonally, release) the move glyph kept popping up next to the cursor (four little arrows - up, down, left, right) and box select would not work. I tried escape, etc. thinking I had inadvertently started a command, but it did not change anything. "Select sketch features" is selected in the selection type drop-down at the top of the screen. I figured out that if I started my box selection off of the part, in open space, it would work, but if my first click was on the part, it exhibits the move functionality. Incidentally, no matter where the move click happens, it highlights and tries to move a workplane.
I can workaround for now, but does anyone have any ideas about this?
Roy Conrad
