Inventor 2022 assembly over constraint issue
manikandanmmkm
manikandanmmkm
I have faced conflict constraint issue on large assembly, because of one over constraint entire assembly will be collapsed. If i constrained the more then sufficient (more then 3 constraint) inventor professional 2022 will allow the constraints (see attachment), but in previous version inventor professional 2018 it will warn the over constraint in the model tree.
johnsonshiue
Hi! Inventor always allows redundant constraints. Try this. Go to Tools -> App Options -> Assembly -> check "Enable redundant relationship analysis." Then go to Manage -> Rebuild All. The redundant constraints will get an exclamation mark.
Many thanks!
Software Test Engineer
manikandanmmkm
Many thanks
