Configuration lines different for imported CAD drawing. Why?
FilipeMais
FilipeMais
Hello everybody,
Can anyone explain me why I get different configuration lines when I import a DWG file?
As you can see BELLOW in this two sketches: In the first one I have green lines and I have blue lines in the other.
I want green lines, but sometimes the lines are blue. Why?
Thanks for your help.
Green lines is what i want.Green lines is what i want.
Even if full constrained the blue lines remain thereEven if full constrained the blue lines remain there
johnsonshiue
Hi! Please share the dwg files. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
FilipeMais
Hi @johnsonshiue,
Thanks for your reply.
The files are now in the attachment.
Best regards
FilipeMais
I understood what was happening.
Simpler than what i thought.
It seems that the color was defined to that color.
If I change it to "By Block" it gives me what I want.
The same with the Line Weight.
Here it isHere it is
