Inventor 2021 Solid Sweep has a mind of it's own??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was messing around with trying to design a router template to print on my 3D printer and wanted to simulate a router bit path around a profile. When I went to go sweep the cutter body around a very simple slot profile, inventor just seems to dream up it's own weird path to follow.
I thought it might be because it was a closed loop, so I converted one line to sketch geometry, but that had no effect. I then thought it might have something to do with using the cutter tangent instead of constrained to a point on the center of the cutter.....but the same result.
