Hi brainstrust,
Im have some real issues with the righ-click menu acting strange after restarting inventor (was previously running for a week straight).
In part files, assembly files, or right clicking off the tree, the menu appears to be sometime off screen, or not showing up at all. Only happening within the Inventor application.
Has anyone else had this issue and is there a fix?
Hi! I believe the behavior you are seeing is similar to the following thread. Try the solution (post #14).
https://forums.autodesk.com/t5/inventor-forum/cursor-and-marking-menu-are-far-appart/td-p/9136851
Many thanks!
