Inventor 2021 Copy Bug
Hello
I just moved to inventor 2021 from 2019. Everything seems to work fine Besides Copy function
The problem is the following. When I'm working on an assembly with several parts in it and I want to use copy function: there are two ways: select part and then use "copy", you can either give the new part different name from the original part and Inventor creates the same exact new part to the desired location (which works fine with me), and also, you can give the same name as original part and inventor creates copy of part, it doesn't create new one and while changing original part, all of its dependents change with it. its like Ctrl+C, Ctrl+V. You just paste the same part several times in the assembly. Well, actually it was how Inventor 2019 used to work. But now, in 2021, when I click on Copy function and give the new item same exact name as original (reusing existing), inventor not paste the new part to the assembly but it deletes the original part I'm trying to copy. and the bad this is that id not deletes from assembly, but from the folder and then it gives me warning "specificpart.ipt" can't be found in the destination folder (which was there before using copy function). So, after this action the original part is deleted from the folder, which means new part can't be created and when I close the assembly and reopen it, the whole assembly missing the part i was trying to copy. This is very disturbing. I lost several part of my project and now I have to create them again and plus cant use copy function at all.
Need Help ASAP
