How to delete rectangular pattern elements OUTSIDE of the inscribed circle?
factotuminventum
Message 1 of 14
factotuminventum
I drew a rectangular patern of circles. 20 rows, 20 collums.
Then I drew a circle rougly the size of the square of circles.
Now I want to delete just all the parts that are not in the circle.
How do I do that?
(Please please please don't say by hand, it's 2020 here.)
Replies (13)
Message 2 of 14
JDMather
Attach file here.
There are several easy techniques - the technique I will demonstrate depends on whether a sketch pattern or a feature pattern is used.
Message 3 of 14
factotuminventum
I used a schets pattern
Message 4 of 14
JDMather
Attach file here and link to image of an example similar to your Design Intent.
Message 5 of 14
factotuminventum
Student version 2017.
Message 6 of 14
JDMather
Why are you using Inventor 2017 rather than Inventor 2021?
Students and schools get the latest version of Inventor for free.
I don't have access to Inventor 2017, but I could show you in Inventor 2021.
Message 7 of 14
JDMather
I drew a rectangular pattern of circles. 20 rows, 20 columns.
Then I drew a circle roughly the size of the square of circles.
Attach your *.ipt file here, so I can see what you have done so far...
Message 8 of 14
CGBenner
@factotuminventum
Do you still need assistance with this question?  You won't find many better teachers than @JDMather .
Chris Benner
Message 9 of 14
mcgyvr
You may need to use ilogic to accomplish what you want..
https://modthemachine.typepad.com/my_weblog/2013/03/control-feature-creation-based-on-user-defined-b...
Message 10 of 14
factotuminventum
Hi JD Mather,
I'm sorry for my late reply. Right after I had send that message I fried my hard drive. So I just bought a new computer and set up 2021 student version as you suggested.
In the attachment you will find the file of the drawing that I am trying to make. It is a baffle plate of a heat exchanger.
What I tried to do is to create a rectangular patern of the circles and then erase all those that are out of or touching the inner circle.
One comment I received from a collegue in training is that he would do the volume of the body first and then select the points that need to be transferred in holes. I did that in the second drawing, but the problem remains. How do I select only those points that are inscribed in the circle?
Thanks in advance for your help.
Erik.
Message 11 of 14
JDMather
Is something like this what you are after?
Message 12 of 14
factotuminventum
Hi CG Benner,
Thanks for your reply. I posted a reply to Mather's answer and had a look at your suggestion. It describes exactly what I was loking for but is way over my head for the time being. Still in trainng...... But thanks for showing me the future!
Erik.
Message 13 of 14
factotuminventum
Yes, exactly that.
Message 14 of 14
JDMather
Attached are two different patterns.
