Inventor 2020 Lag and Pounding Paging File???
phlyx
Message 1 of 21
phlyx
New workstations with Windows 10 (all updates), Radeon Pro WX 8200, and upgraded to Inventor 2020.2 and have hanging, lagging and crashing issues.  Last week also had a couple BSOD's with MEMORY MANAGEMENT issue and issues with SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (atikmpag.sys). Trying to work thru the issue(s) but today noticed that although we have 64GB RAM, when we're opening a large assembly or opening Inventor we only are using a small portion of our RAM but we're reading/writing like crazy to the Windows paging file (Hard Faults/sec using paging file).
We have OS managing paging file size and our files all exist on the network drives, so not sure why we're hitting the paging file so much which is also extremely s-l-o-w compared to the RAM.
Just curious if anyone has any hints or tips as we're struggling here.
All help is greatly appreciated.
Replies (20)
Message 21 of 21
phlyx
Hi Johnson, I'll put a reminder to do that but we run aggressive design schedules and pretty swamped right now.  Still running good without hardly any issues now so <knocking on wood> hoping it stays this way.  Do have a complicated mold tooling model and it takes forever for Inventor to open it and just hitting a command when it's open can sometimes take a couple minutes.  I copied it local and it was pretty much the same response time.
I'll disconnect sometime and see if that changes anything.  I'll get a common assembly and time it opening from the server, from local, then local no network if I can.  I believe licensing is on the network or internet.
