Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi Friends,
I have a new computer and Inventor 2020 is installed. I designed a bake lite container which we use for plastic bake lite.
I selected the color to white, because the container is snow white. But as you see, he is gray.
How can I turn it to a really white.
See picture.
Thx
Solved by Mark.Lancaster. Go to Solution.
Look at the appearance tab, open the appearance window, right click on the appearance and select edit, you can then change the colour or tint for that appearance.
If you look here you can see if tiniting will affect any other visual features: https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
See the solution here https://forums.autodesk.com/t5/inventor-forum/white-isn-t-so-white-any-more/m-p/3593046#M445786
Mark Lancaster
& Autodesk Services MarketPlace Provider
