Inventor 2019 resolve link error
Message 1 of 15
I am trying to open assembly(in Inventor 2019.3 ) whose file version is 2013 and it has piece part(as reference) whose file version is 2019.3.(project file is selected prior to opening of the assembly)
Although the file is present, inventor shows the resolve link window and navigates to the folder where the file is present but not able to establish the link between the assembly and the part.
What could be the reason ?
Replies (14)
Message 2 of 15
johnsonshiue
Hi! Could you open the same ipt file by itself? Please install 2019.4 update and report back your findings. If it still fails to open, please share the file here.
Many thanks!
Software Test Engineer
Message 3 of 15
@johnsonshiue yes i am able to open the ipt file itself (project file is activated before opening).
I cannot update the Inventor version as I am working on the client's machine.
Message 4 of 15
@johnsonshiue one more information i got is the users are using Autodesk Vault 2019 from last month, before that they were using Autodesk Vault 2017.
Also when we are downloading the data for migration to Teamcenter, we are using Autodesk Vault 2017.
so do you think this could be the reason ?
Message 5 of 15
johnsonshiue
Hi! I don't think this is related to Team Center or Vault. Inventor fails to resolve to the file because it cannot open it. I cannot explain the behavior unless you can share an example.
Many thanks!
Message 6 of 15
I am attaching the data for your reference.
Message 7 of 15
johnsonshiue
Hi! I am not seeing an issue with the files you attached. Do you use Inventor Project? You did not include an ipj file in the attachment. I created one project pointing to the folder where the files were. I was able to open 0252-71259_REV_1.iam without any prompt. SHCS M8x50.ipt resolved correctly.
The files are saved in mixed releases. 0252-71259_REV_1.iam was saved in 2013. And, a subassembly was saved in 2017. SHCS M8x50.ipt was saved in 2019.
What release of Inventor are you running?
Many thanks!
Message 8 of 15
@johnsonshiue there is project file inside the project folder if you use that ipj file and open the same assembly which you opened it will give you the resolve link error.
To open the assembly i am using Inventor 2019.3
Message 9 of 15
johnsonshiue
Hi! I think I see the confusion now. The unresolve behavior is due to the fact that the Project Library path settings are not set correctly. Library files are usually stored in a place outside of Project Workspace. When you relocate the library path, you need to remap them properly in Project -> Libraries. Otherwise it will not work. Also, you should change file path outside of Vault. Or, Vault will have trouble finding those files.
After remapping the library path, Inventor should be able to find the files if they are in the search paths.
Many thanks!
Message 10 of 15
can you share the project file that you created or else you can give me the steps to create the project file
i will try to see if that is resolving the error.
This is one of the no of issues we are facing..
other issue is like we are selecting a project file and trying to open an assembly but it gives resolve link error even though physical file is present...
may be i can test this case with the steps you will provide for creating ipj file..
thanks @johnsonshiue
Message 11 of 15
johnsonshiue
Hi! The project file that works with your dataset is pretty simple. Basically, you need to define the Workspace at the level where all sub folders are included. Inventor should be able to find the files within the project cone.
What you might have done was altering the Library folder path on disc without properly mapping back to the Library path settings in the project file.
Many thanks!
Message 12 of 15
Hey Thank You John..
I found that the project file had wrong library path for one of the libraries after correcting that, most of the invalid issues got resolved..
can you just check the project file settings.
I am attaching the project file and snapshot of the work space with sub folders inside it. Please let me know if the mapping is correctly done.
Message 13 of 15
johnsonshiue
Hi! Yes, it should work. The only change I would make is to the Workspace setting. In your case, it should point to "Projects" folder. In this way, you have clear separation of Libraries and Workspace.
Many thanks!
Message 14 of 15
Hi @johnsonshiue
Thank you for that information, it really helped.
Message 15 of 15
Hi all,
I have a bit different issue than the above written. I think the mistake I've done is that I've copy-pasted parts from an other assembly to mine, but that other assembly is also in the project folder. When I try to open the assembly Inventor offers me to resolve a link, but it looks for a #data.ipt file. (Picture attached).  It doesn't care what .ipt file I try to open, I get always the same error message and I can't resolve my assembly. Can someone help me with this?
Many thanks.
