- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I only have Inventor 2019 installed, so this is not tested in 2020. If this is already fixed in 2020, never mind fixing it in 2019, as it is a minor annoyance.
The Centroid calculated by the "Region Properties" command for a sketch seems to only work for sketches in the part's origin XY plane. In the attached example, the centroid is correctly placed on Sketch1 in the XY plane, but in -5,0 on the side of the square for Sketch2 in the XZ plane. My guess is that the centriod is first calculated correctly, and then a bug projects it into the origin XY plane.
PS: I tried to attach the ipt file, but only get an error "The attachment's regionproperties.ipt content type (application/octet-stream) does not match its file extension and has been removed"
