Inventor Forum
Inventor 2019 loading file very very slow
15 REPLIES 15
Message 1 of 16
1523 Views, 15 Replies
When the user open Inventor everything is fine, but when he open a file he need to wait like 30 min atleast before the file is opend. Normal is this around 2 min. How can we fix this?
- Videocard is up to date
- Drivers are up to date
- Windows is up to date
- C:\%temp% << Delete all file in here
- PC have been restarted
- Files for Inventor are placed local on the machine
All these things don't have any effect.
Does anyone have a idea?
15 REPLIES 15
Message 2 of 16
MoshiurRashid
Does it happen everytime or after start up of windows?
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 3 of 16
leowarren34
Am I right to think same spec pc?
If it's an assembly how many parts?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 4 of 16
johnsonshiue
Hi! Have you applied 2019.4 update followed by 2019.4.4 update? Also, if you unplug network, does file open speed up?
What is your machine spec?
Many thanks!
Software Test Engineer
Message 5 of 16
in reply to: johnsonshiue
"Hi! Have you applied 2019.4 update followed by 2019.4.4 update? Also, if you unplug network, does file open speed up?
Many thanks!"
Yes Inventor is up to date and unplugging the network doesn't help.
"Does it happen everytime or after start up of windows?"
It happens everytime
" Am I right to think same spec pc?
If it's an assembly how many parts?"
Its same spec pc, special chosing for this program and since a week it is very slow. Before that everything was fine. In that time period only windows update came out and where installed.
Message 6 of 16
leowarren34
As Johnson asked what spec is your PC?
What is your windows build?
Leo Warren
Message 7 of 16
mluterman
I had the same problem (we run off a network without Vault)...until I learned all about project files (.ipj) and their effect on search times.  It had nothing to do with hardware at all; just the way Inventor looks for all files that "tree-off" of a high-level drawing (.iam or .dwg).
Message 8 of 16
mluterman wrote:
I had the same problem (we run off a network without Vault)...until I learned all about project files (.ipj) ....
@Anonymous
With this in mind,
If you edit your Project file and expand the Options node in the Edit Project pane, you'll see the Using Unique File Names option. I typically recommend setting this to No even if you are using unique file names (which I also recommend). This setting doesn't really enforce unique file names, it merely searches for them. So I find it to cause more problems than it solves.
Where I find it to be particularly problematic is when I rename a file in order to purposely break a link so that I can resolve the link to a different file. For instance when working with derived parts and trying to point the part to a new revision of the derived part file. If Using Unique File Names option is set to Yes, Inventor searches every folder/file in the project and takes a long time to tell me what I already know: the file can't be found. However, if I set this option to No, Inventor immediately throws the resolve file dialog and allows me to redirect the link.
In your case where there is not broken link, it might be that it is still doing the search/comparison to see if there are unique file names and that is causing the slow open time.
Anyway, you might try setting this to No to see if this is the problem.
I hope this helps.
Curtis
Message 9 of 16
in reply to: leowarren34
What is your windows build?"
Here are the specs and windows build.
Windows build: Microsoft Windows 10 Pro 10.0.18363 (newest version)
Model: HP Z230 Tower Workstation
Serial Number: CZC5457HD3
Motherboard: Hewlett-Packard 1905
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Physical Cores: 4
Memory: 31.8 GB
Display Adapter:
NVIDIA Quadro K2200
BIOS Version: L51 v01.62
BIOS Release Date: 2019-06-10
@Curtis_Waguespack
Thanks for your answer. I will sure test this today and check if the problem is solved.
 I keep you guys updated
Message 10 of 16
in reply to: Curtis_Waguespack
I tried your solution and it did fixed something in the load proces, but still not very fast. Might take a few min less then before, but still alot of time.
Message 11 of 16
johnsonshiue
Hi! This is still puzzling to me. The hardware looks fine. It is quite similar to some of our internal engineering desktop machines. You mentioned that all files are local. What about Materials and Appearance Library? Is it local too?
Many thanks!
Message 12 of 16
Materials and appearance are local too on the system. We are thinking to re-install windows on this device. We encounterd more problems with other programs too last friday. Like Word being slow too for no reason.
Thanks for the help. Ill keep you updated about the status.
Message 13 of 16
johnsonshiue
Hi Erwin,
Are you dealing with large files (size > 250MB maybe)? We are aware of a Windows Defender issue causing large files to load very slowly. We are working closely with Microsoft to address the issue. The fix may come in form of a Windows update.
You can test my theory by running a different Anti-virus program or switch off Windows Defender for a moment. Then retry the slow workflow.
Many thanks!
Message 14 of 16
Not a large file 🙂
We did a re-install and the problem is gone 🙂 Thanks for the help guys!
Message 15 of 16
leowarren34
Anytime, happy to help 🙂
Leo Warren
Message 16 of 16
johnsonshiue
Hi Erwin,
It may be Windows Defender related like I mentioned earlier. Microsoft has just provided a fix as part of Anti-Virus update. It is possible your system has the update installed right around the time you were reinstalling Inventor.
Many thanks!
