Inventor 2019.3 and 2019.0.2 updates are available in Autodesk Accounts. The updates contain important fixes for our 2019 users. 2019.3 is a cumulative update and also includes all the enhancements from the 2019.1 & 2019.2 updates.
You can can see the release notes here
Hi Loren Im on inventor 2019.02 update under account, I dont have access to .3 or .4 update, How ever under the latest windows 10 1903 build frame generator and access to content center no longer works, can you please clarify what is the best solution to fix this is please.
Thank you Peter
If you don't have access to the latest update for Inventor 2019, your only solution at this time is to roll back the Win 10 1903 update.. If its too late, there's nothing else you can do unless you want to rebuild the OS/computer from scratch and not allow it to install the 1903 update.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi Peter,
Are you a subscriber? If yes, you should have access to the updates. Based on your description, you are running Windows 10 build 1903 and the Content Center and related workflows are not working. Without 2019.4, you will have to roll back Windows 10 build 1903. Or, upgrade to 2020.
Many thanks!
Peter -
I don't have much to add to what Mark and Johnson have said. Can you verify if you are a subscriber or still on maintenance? If you are, and cannot access the 2019.3/4 updates then you will need to start a support ticket to address that with your account.
-lw
