I tried installing Inventor 2018 using a student key. I downloaded the auto-installer and it said "0b/s" forever so I tried the browser download and went to bed. I awoke to the three separate installer files downloaded. I ran the first one, gave it the necessary directory, and it downloaded the Desktop App to do the rest. Once the DA was open I was able to run the updater and update it as needed. I then tried to run it, it opened the splash screen and closed. After that I decided to google the issue. I found an answer saying to repair the files, did, same result. I tried to reinstall, did, same result. I tried to run the Inventor.exe /install with CMD in admin mode, did, same result. Nothing seems to work.
I'm running Win7, 64bit, with GTX 1060, i7 4790k, 32gb ram, all drivers up to date.
Hello @Anonymous,
Have you tried below methods?
https://forums.autodesk.com/t5/inventor-forum/inventor-2018-won-t-launch/td-p/7081361
By the way, have you installed the .Net4.7 and up to date?
Hope it helps!
Hello @Anonymous,
Hope it helps!
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Hello @Anonymous !
