Inventor 2018 LT crashes after running Inventor Reset Utility
markKM8CP
markKM8CP
Will start OK until I try to ' Start 2D Sketch', then crash ...
Will not open any .DWG file
Thank you!
Mark in Reed City MI
johnsonshiue
Hi Mark,
Try this. Go to Tools -> App Options -> File -> Configure Default Templates -> select the desirable standard and the unit.
After that, does it work better now?
Many thanks!
Software Test Engineer
markKM8CP
Thank you for your help, but I still get the same result ...
johnsonshiue
Hi! I suggest you uninstall Inventor 2018 LT and reinstall it. The style library might be corrupted. You have to reinstall to restore the library. The Reset Utility only reset the settings.
Many thanks!
