- Mute
- Permalink
- Report
From the Readme file for the 2018.1 Update
http://up.autodesk.com/2018/INVNTOR/Inventor_2018.1_enu.htm:
Part Modeling
The performance issue loading Thread/Clearance data is resolved. Inventor now reads the Excel spreadsheet for Thread or Clearance data using the Excel libraries, and no longer loads Excel even when Excel is installed on the local machine.
ATTENTION: The environment variable UseLibXL is no longer required, and should be removed from your system as it can prevent Excel from being used for table write operations.
From the document: What's New for Inventor 2018.1
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-35383566-95AE-4F7A-AEA7-C27CB0ACCE18
Other General Enhancements
Attention: Previously customers were directed to add the environment variable UseLibXL=1 to resolve the performance issue with loading Thread/Clearance data. The environment variable UseLibXL=1 can be left in place if it is already in use, (or, if it is not already in place, add UseLibXL=1 as an environment variable), as it may continue to improve the performance of iPart/iAssembly related workflows.
I think that a final and clear word by Autodesk about this subject is needed.
Best Regards
G. Barozzi
