- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I work in an environment where there can be no outside connections from our CAD Stations.
In developing my install deployments I have been un-selecting everything that has anything to do with cloud use.
Also hacking the ini files to remove any calls for Adsync, etc.
Even with doing all of that there are many pieces that get installed anyway that I then must go back and un-install.
One of these pieces is Inventor Connected Desktop for A360.
Even though this has been un-installed when you first launch IV the little icon for it still shows up in the IV Window.
If you select it you will get an error because the program has been un-installed.
You can make it not be visible from the View menu.
I need this to not be there for the users to see without their interaction to turn it off..
