@Anonymous wrote:
I am a new user, running Inventor 2017 Educational. I wish to use a .ipt file created elsewhere, but on opening it I receive an error message (see attachment).
I do not seem able to access the required update 2017.4.4, presumably because of the lack of subscription on my license?
I would be grateful for any advice.
Thank you.
Mark
Assuming you get the licensing sorted out (Educational should have fully access to all updates AFAIK) make sure you are aware that Inventor files are NOT backwards compatible..
This "anycad" allows you to reference newer files but does NOT allow you to modify them as if they are a native Inventor file created on the same version you have..
As a new user I caution that you shouldn't be mixing versions and if you are in a class use the same version the school uses and don't install a newer version at home or anything else..
Why do you only have 2017 anyways? 2019 is out and as a student you have access to it.. But again.. If your school is only on 2017 then stay with 2017 at school and at home..
