Announcements
Inventor 2017 Pro Drawing Enviroment Weld Symbol Placement Progam Freeze
chrishutchinson6848
chrishutchinson6848
I've been trying out the new Inventor 2017 Pro and have been experiencing a program freeze when I place a weld symbol in a idw file.  It seems like I consistantly have this freeze only upon the first attempt to place a welding symbol after starting up my laptop.  After forcing Inventor to close and restarting it I can place weld symbols with no further freezes.  I've attached a screen shot of how the weld symbol dialog box is missing some elements (leader & all around symbol selection box).
I've also noted that when I do successfully place a weld and select the weld type I get a persistant screen display glitch where the weld type selection remains displayed and will not go away without restarting windows!
Chris Hutchinson
Charlotte, NC
Replies (108)
andrewdroth
Still does it in the Standard Template.
And it shouldn't be our template causing it because we have machines that don't have this issue.
It must be a graphics card / driver issue.
Machines without the Issue
NVIDIA Quadro FX 1800 - Driver Version 9.18.13.697
NVIDIA Quadro FX 1800 - Driver Version 9.18.13.3523
Machines With the Issue
NVIDIA GeForce GTX 980 Ti - Driver Version 10.18.13.5330
NVIDIA GeForce GTX 980 Ti - Driver Version 10.18.13.5891
NVIDIA GeForce GTX 980 Ti - Driver Version 10.18.13.6510
NVIDIA Quadro FX 1800 - Driver Version 9.18.13.4195
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
andrewdroth
Maybe it's not a graphics card thing either.
I just tried it with 'Software Graphics' enabled, and it still happens.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
Can anyone from Autodesk comment whether this is a software or hardware issue?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Xun.Zhang
Hi All,
Thanks very much for such details, it's now under investigation and was tracked internally as Bug 132483, will reply it for any progress.
Xun
JimBackull
Exactly the same problem here...
Inventor freezes when placing the first welding symbol, after force closing and restarting Inventor it works just fine.
All four users in our team experience the same behaviour, even though we have different computers (both old and new ones with different internals).
Hope you´ll find a fix for this!
- Jim
Jim B
andrewdroth
Just downloaded 2017 R2, and the issue persists.
This needs to be fixed soon. It's causing a lot of lost work.
undefined
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
BUMP
LishuangLu
Hi andrewdroth,
Thanks for confirming with R2 build!
Would you please try whether it works for you with below experiment?
1)      Close Inventor.
2)      Go to Control Panel -> System -> Advanced System Settings -> Environment Variables -> add “DYNAMIC_LOAD_APPLETS” and set the value to 0.
3)      Start Inventor, try the Weld Symbols again
Let me know if there's any result from your side, thanks for your cooperation as usual!
-Lisa
JimBackull
I tried your fix, but it didn´t help.
The problem still remains and Inventor freezes.
Like before it works if I first open Inventor, make Inventor freeze by trying to apply a welding symbol and then restart the program after force closing it.
But of course after every reboot the problem comes back.
Jim B
LishuangLu
Hi JimBackull,
Many thanks for your help to try that and reply back!
We have tried on several machines in our side, however, we still could not reproduce it.
Some other experiment may need your help to have a try:
1. How about unload all addins?
2. Do you have other special settings in your OS? such as DPI, or other special software being used together?
Thanks very much for your help to investigate this issue!
-Lisa
JimBackull
No problem, just want to find a solution to the issue 🙂
1. Still freezes.
2. Not that I can think of. Also two of our four computers are quite new with basically nothing extra installed besides Autodesk software and some other required software we need like Office-programs, Adobe-programs and various business management programs.
Jim B
LishuangLu
Hi JimBackull,
Thanks for your patience!
Would you mind contacting me via email to follow up on this?
My email address is: Lishuang.lu@autodesk.com
-Lisa
andrewdroth
I tired both the environmental variable and unloading all the add-ins. Neither worked here either.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
DannyHubbard
 It appears that is maybe that Inventor is having a hard time finding the font file to be used for this dialog (amgdt.shx). Can you check the Windows system path and the Inventor Application Options, mainly the File tab, to make sure all the paths are valid. Speculation is that there may be a path referencing a server or drive that no longer exists. Might also check the Start in location on the desktop icon used to start Inventor.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
klbosch
Hello Danny
 A customer just pointed this issue out to me as well. i tried it on my own system with complete default settings and i have the same issue. it only appears to be the weld symbol that has a problem. Please note i have Inventor professional 2017 R2 installed.
Is there any movement one this?
andrewdroth
All the paths seems to be OK. Why would this only affect the first time the weld symbol is used? It's fine after it crashes once.
Did something change in this dialog for the 2017 release? This has never been an issue before.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
DannyHubbard
Any chance you can run Process Monitor on one of your system, Filter it only Capture for the Inventor.exe process. Then post the logs, we still are trying to narrow down what is causing the issue. Developments first thought was around the path but that doesn't appear to be the case.
https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
andrewdroth
Here you go.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
karthur1
We are seeing a similar issue on two separate machines.  Both are running 2017 R2.  When I first attempt to place the weld note, Inventor will freeze.  I too have to force Inventor to close.  When I restart Inventor, I am able to place the weld note.  However, I  am not missing any elements in the weld symbol dialog.It seems to work fine after that, but there are some graphic artifacts left behind that I cant get rid of unless I restart the machine..... Then I can't place a weld symbol and I have to force Inventor to close.  Its an endless cycle.
We have found that to get the artifact gone is to change the windows theme to a different one (Default for instance). It is then removed and I can change the theme back to my personalized theme.
Any help on resolving this issue would be greatly appreciated.
karthur1
I just noticed that after changing the windows theme.... there is eventually an artifact that appears on the screen again Smiley Sad.  Its in a different place this time.
Kirk
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
