Flat pattern from large bend radius solid
Hi All, I am trying to make a flat pattern sheet metal part derived from a lofted 3D solid (see attached file). When I press the command the program simply reorients the part, resulting in no flat pattern or error messages to lend aid. I would prefer to do this starting with a sheet metal part instead of "make from" solid part. Thanks
Replies (7)
JDMather
@Anonymous wrote:
.... I would prefer to do this starting with a sheet metal part ...
Did you use Lofted Flange?
No file attached?
Yes, I can make the part using the lofted flange but one cannot save the flat pattern of a lofted flange. I did find a low precision work around that copies the surface geometry of the flat pattern produced but it's not ideal. Any other technique that allows saving of the flat pattern?
JDMather
That is incorrect information.
Of course the flat pattern can be saved.
Attach your *.ipt file here and end all doubt.  (you might try attaching with a different browser)
This is the type of shape I'm trying to make.
It will not let me export the flat pattern as a .stl for manufacturing. Says I "must exit flat pattern edit mode to save" but I need the flat pattern geometry to go in my CNC router.
JDMather
Edit your Cut and change to Normal or the cuts will not be perpendicular to the flat.
To get the Flat Pattern as an stl will require two steps.
Right click on the Flat Pattern node in the browser and Save As type *.sat.
Open the *.sat and Save Copy as *.stl.
But I am surprised that your CNC router uses stl.  Stl is faceted triangles that I would expect to cause problems for a router path.
Thanks! That method worked for the part I posted! Now I am having trouble editing cuts to "normal" in the attached file.
The router takes Gcode from "Meshcam" which needs a .stl file to set-up.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
