Inventor 2017 Pro Drawing Enviroment Weld Symbol Placement Progam Freeze
chrishutchinson6848
chrishutchinson6848
I've been trying out the new Inventor 2017 Pro and have been experiencing a program freeze when I place a weld symbol in a idw file.  It seems like I consistantly have this freeze only upon the first attempt to place a welding symbol after starting up my laptop.  After forcing Inventor to close and restarting it I can place weld symbols with no further freezes.  I've attached a screen shot of how the weld symbol dialog box is missing some elements (leader & all around symbol selection box).
I've also noted that when I do successfully place a weld and select the weld type I get a persistant screen display glitch where the weld type selection remains displayed and will not go away without restarting windows!
Chris Hutchinson
Charlotte, NC
Replies (108)
chrishutchinson6848
I can now say I have the welding symbol placement freeze on every initial start of Inventor 2017 after my laptop startup.
I've downloaded the suggested display driver for my Quadro K5000M video card from the Autodesk Certified Hardware web site and installed it.  I've attached the Inventor hardware diagnostic report to show my current driver configuration.
I was looking at the task manager with Inventor 2017 loaded and note that the program acwebbrowser.exe has NINE lines loaded (see attached screen shot).  I know in the past that the program has caused me problem in earlier versions.  Is this many instances normal?
Chris Hutchinson
Charlotte, NC
mdavis22569
Can you share an example file ?
Mike Davis
chrishutchinson6848
I open Inventor 2017 Pro using the default project and start a new default idw file.   When I place the weld symbol on the drawing it freezes.  I then force Inventor 2017 to close and restart it.  I can then place the weld symbol but I get the grapics problem with the ghost image.  This ghost image doesn't have to be something from Inventor 2017 its just the first app selected.  If I RMB the desktop and select lets say NVIDIA control panel the ghost appears and only a reboot will get rid of it.
Chris Hutchinson
Charlotte, NC
chrishutchinson6848
Here's a update:
I uninstalled and then reinstalled the 2017 Product Design Ultimate suite.  Just as after the intial install everything installed OK, but I still have the Inventor 2017 idw weld symbol placement freeze and the display ghost problem.
Chris Hutchinson
Charlotte, NC
mercerc
When you uninstall Inventor is it what we refer to as a clean uninstall (no the one in control panel)?
I've tried to repeat the issue in several different ways.
1. just an idw open (no file).
2. Idw with standard assembly file using weld annotations
3. Idw with welded assembly file, plus using welding annotation.
In each case, I couldn't get the weld symbol to hold up Inventor.
Have your templates been migrated ?
Have you tried if not already our default templates?
Charlie M
Inventor Product Support Specialist
chrishutchinson6848
Charlie, I used the uninstall tool in the Start_All Programs_Autodesk folder.  Can you provide the instructions or link for the "clean uninstall" procedure?
I have the weld symbol placement freeze (only after the initial laptop startup) happen when using the default project & default idw with no ipt attached.
Is the multiple instances (9) of the custom autodesk browser program acwebbrowser.exe seen in the task manager process tab common? (see my earlier post no. 2)
Chris Hutchinson
Charlotte, NC
ChrisMitchell01
Chris,
Regarding the multiple processes; yes that's normal. They relate to an embedded Chrome component which is now being used in a variety of ways. For Inventor we use it to display the MyHome screen; it's also used as part of the licensing module & within the Autodesk Desktop App.
If you disable MyHome & exit Desktop App you should see those & processes go down to 3, (for licensing).
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
andrewdroth
We are seeing the same issue on three different machines.
Go to insert a new symbol, and the dialog box doesn't diplay properly and freezes the program. There is often a display ghost left behind also.
See Screencast below of the steps used to cause the issue.
It seams like after it freezes once, the problem goes away the next time you start inventor, until you restart the computer. But I need to test it some more.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
andrewdroth
After a bit more testing and restarting the computer a few times I found that if you leave the weld symbol dialog box open without clicking on anything it will sort itself out after a couple of minutes.
After doing that once, now the box sorts itself out after a few seconds each time. Still not as immidiate as you would like to see, but worth pointing out.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
nathanr
Looks like bolted connections from here on out!
The amount of time I've "saved" with newfangled bs features brought out with every requisite yearly release of this software is a fraction of that I would have if the basic functionality just worked.
How about take a year or two off and fix the software, then release AUTODESK DOM 2020 and take over the world?
andrewdroth
Bump!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
chrishutchinson6848
This weekend I installed Inventor Pro 2017 on another laptop a Lenovo W530 running Windows 7 Enterprise.  The original install was on a Dell Precision M6700 running Windows 7 Pro.
This Lenovo laptop also has the exact same problem with placing a weld symbol.
The only thing these laptops share is having a Nvidia Quadro video card.  The Lenovo W530 has a K1000M and the Dell M6700 has a K5000M.  They both have the latest video driver downloaded from Nvidia installed, i7 CPU's, 16 GB RAM, use a 3Dconnexion Space Navigator 3D mouse, and plenty of hard drive space for the installation.
Chris Hutchinson
Charlotte, NC
andrewdroth
We are seeing this on machines using Nvidia GTX 980 Ti, and Quadro fx1800.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
This is still a daily issue for us, have Autodesk contacted you about this in any way?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Couple fellas I know, one works in the helicopter business and the other in architecture, I think the airplane place uses less autodesk products, of course revit is in play - say that adesk support is as useless as **** on a boar and to try disabling hardware acceleration.
My friend is just getting HAMMERED by this bug!  Hours down the toilet.
Suggested workaround - save drawings to .dwg, detail in AutoCAD
andrewdroth
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
TheCADWhisperer
I tried to reproduce and everything working fine here.
Does this happen with the OOTB drawing template, or only with your customized company template/
Can you attach a file here that exhibits this behavior?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
