Inventor 2017 on Asus ZenBook 14 UX433FN?
Does someone know if Inventor 2017 will run on an Asus ZenBook 14 UX433FN?
I know it is not a perfect combination, but I want a lightweight computer for different reasons.
Specification for the laptop mentioned above is:
- 16 GB RAM
Intel Core i7 8565U
- Graphic card: GeForce MX150 with 2 GB VRAM (GDDR5)
The processor will normally work with 1,8 GHz (quad core) but can operate with up to 4 GHz periodically, if I understood the seller correct.
Best regards
Urban
Frederick_Law
It should run reasonably with small (<500 parts) assembly.
leowarren34
It will be an allright system but will not be amazing as the CPU is a huge limit and the GPU may cause problems depending on textures and shadows used, the CPU speed ideally needs to be higher?
What is your use case?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Frederick_Law
8th Gen 4 core i7 4.60GHz Turbo a huge limit?
Which CPU is not a limit?
leowarren34
You cannot rely on the turbo as it depends on cooling solution and environment, 1.8gHz is the only figure guarenteed to run across all cores but turbo generally only acts on one which is the huge limit.
Leo Warren
leowarren34
Checkout intel arc: https://ark.intel.com/products/series/122593/8th-Generation-Intel-Core-i7-Processors#@mobile
Ideally you want atleast 3gHz preferably closer to 4 for optimal performance.
Leo Warren
