See screenshot below. I didn't have this problem on the last model I worked with. I've searched numerous keywords trying to find the answer but I haven't found anything discussing this issue. My viewcube is not at a wierd angle or anything. I personally hate isometric view dimensions but have to do it this way for sales spec sheets. Anyone have this problem before or know how I can get the text to align with the leader arrow extension lines???
Please let me know what you think.
Sam
Solved by okaleja. Go to Solution.
Hi! The behavior does look odd. I am able to reproduce the behavior. It does have something to do with the view direction. If you rotate the view, does the dimension value look better?
Many thanks!
Thanks for the reply Johnson. I played around with the view rotation and found out that this is causing the issue. If I create a custom view orientation by just clicking the corner of the view cube (without any further adjustment) the dimensions come out ok. If I do that same thing but drag the view cube down slightly after clicking the corner, the dimensions look all out of whack. May just have to use the standard orientation from just clicking the corner and be done with it.
Just a follow-up: I couldn't get the dimension text to align so I just hid the dimensions and faked them with non-leader text that I was able to rotate to my liking. Must be some kind of weird bug.
Hi Sam,
You should be able to fix that by modifying dimension style. Please check the following options:
For aligned and vertical dimensions make sure to select "Inline - Aligned" or "Inline - Vertical" orientation.
Hope this helps,
Oto Kaleja
