Inventor 2017 Convert Multiple Surfaces To One Smooth Surface
m_morcielago
Message 1 of 13
m_morcielago
Hello dear
I work with Inventor 2017 pro
I have a full multiple surfaces part and I wanna convert it to one smooth surface
Take a look :
I want to remove the separate lines between surfaces
Replies (12)
Message 2 of 13
S_May
HI @m_morcielago,
that does not work, they can not just delete a tangent...
2018-02-22 09_26_10-Autodesk Inventor Professional 2018.png2018-02-22 09_26_33-Autodesk Inventor Professional 2018 - [39# Fuß.ipt].png
this tangent s also exist in free form:
2018-02-22 09_31_55-Autodesk Inventor Professional 2018.png2018-02-22 09_32_27-Autodesk Inventor Professional 2018.png
Message 3 of 13
Thomas_Savage
Hello @m.morcielago
I have done a screencast on how to convert your multiple surfaces to just one surface.
Is this what you wanted?
Thomas.
Thomas Savage
Design Engineer
Message 4 of 13
m_morcielago
Thank you for trying
But I have another problem with this part
I need to remove that lines between each surfaces.
I want smooth surface like the sole
Message 5 of 13
S_May
Message 6 of 13
m_morcielago
Because I need it for Autodesk Lastmaker software
Look :
In this case I need to select side of model(seamlessly) but as you see I can't do it.
It select me a single surface of side
I need a seamlessly surface for side of part
Message 7 of 13
m_morcielago
Is there any way??
I am still waiting
Message 8 of 13
johnsonshiue
Hi! The lines you are seeing on the surface are called trim loops. This foot model was created by multiple smooth trimmed surfaces. I am not a way to convert these trimmed surfaces into a piece of trimmed surface easily. In Inventor, you could try using Freeform Convert workflow to convert the faces to Freeform body. I had tried it but I did not get satisfying result due to the following reasons.
1) Freeform Convert only works on 4-sided or 3-sided trimmed surface. If a given face has a round loop or more than 4 sides, you will need to split the face first before converting it to Freeform. You could use 3D Sketch -> Curve on Face to create curves to split the faces.
2) The resultant Freeform bodies may deviate from the original faces slightly. The deviation is small but it does exist depending the complexity of the source face. I am not sure how tight or accurate you are looking for. It may not be acceptable.
3) The resultant Freeform bodies are still individual pieces. You can use Merge Edges command to connect all pieces into one. However, this process can be tedious and it can change the surface further, deviating from the source.
This is why I don't think Inventor has a reliable workflow to do exactly you are hoping for this particular case. If I were you, I would do it in the source surface file. How was the surface created in what CAD package? Another question I have is why you about the trim loops? The faces on either side of the trim loops are smoothly connected. Technically, the entire model is smooth if you machine to spec. Do these trim loops present challenge for your process?
Many thanks!
Software Test Engineer
Message 9 of 13
TheCADWhisperer
@m_morcielago wrote:
Because I need it for Autodesk Lastmaker software ....
Do  you have a web link for information on this software?
Is there an Autodesk Forum for this software?
Message 10 of 13
m_morcielago
Thank you for your attention
This 3D part made by 3d scan technology and I have just this by this format and this shape
I'm looking for 3D surface software that help me on this project.
I cannot change source of files.
Message 11 of 13
m_morcielago
Yeah I sent a message for customer service but they answered me :
Thanks you for your inquiry.
As part of a strategic review, the decision has been made to cease investment in our vertical market footwear products.
Support for all Crispin and Orthotic products has now come to an end as of 31st December, any support questions should be referred to your local reseller.
Autodesk has many products and services which enable our customers all around the world to optimise their design and manufacturing processes.
For product design, Fusion 360 connects your entire product development process. Visit the website here
For sole design, PowerShape combines the strengths of surface, solid, and mesh modeling to prepare molds, dies, and other complex parts for manufacture. Visit the website here
For Insole inquiry’s, Elinvision develops and produces 3D scanners in orthopaedic market. Visit the website here.
Kind regards,
Autodesk Footwear.
Please note that this inbox is no longer monitored.
Message 12 of 13
m_morcielago
Hey guys I did it finally
We didn't need to make these surfaces smooth
I just exported my model by .STL format and then , shoemaker software recognize it easily.
Thank you so much for your time
Message 13 of 13
TheCADWhisperer
I just exported my model by .STL format ..
So really, rather than make smooth - you made faceted planes.
