Inventor 2016
Inventor 2016
Message 1 of 18
Inventor 2016
Hi
I am having troubel getting my Inventor PRO 2016 to get started... When I open the inventor I cannot get the home page up nor start a new sketch?
See ATT. below of picture. The arrow only stands and blink (looks like it is working but nothing comes up).
Anyone any idea what could be wrong?
Brg.
Morten
Replies (17)
Message 2 of 18
ChrisMitchell01
Hi Morten,
If you look at Tools, App Options, File tab. What do you have set for the team WEB section ? by default it should show %PUBLICDOCUMENTS%\Autodesk\Inventor %RELEASE%\Web\en-US\CustomHelpSample.htm & "Make Team Web the default page in MyHome" should not be checked.
It sounds like you may have redirected MyHome/Team Web elsewhere.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 3 of 18
Hi
I cannot find these options on my computer... I have windows 7 service pack 1 currently on my computer. Everything worked fine until about 2 weeks ago, then something happen. I also noted tha all the web sistes I had passwords on disapered and I had to put them in again. Don't know if this has anything to do with it.
Brg.
Morten
Message 4 of 18
Hi Chris,
My mistake I was looking on the computer and not inventor for what u refered to. See ATT: for the things I have in the menu.
Brg.
Morten
Message 5 of 18
ATT. of file menu
Message 6 of 18
ChrisMitchell01
Ok try deleting this file - (preference file for MyHome):
%appdata%\Autodesk\Inventor 2016\myhome.json
If that doesn't work, uncheck the option from the App Options General tab for "Show MyHome on Startup" & then exit/restart Inventor to ensure that other aspects of Inventor work OK.
Chris
Chris Mitchell
Autodesk, Inc.
Message 7 of 18
mcgyvr
@Anonymous wrote:
Hi
Brg.
Morten
Can you even start a new part file (ipt?) ?
Using the new button then clicking on a part template? Forget my home.. Just the regular way..
And another tip.. Use the Windows snipping tool to easily capture/save screenshots without having to use word..
@ChrisMitchell01 Chris is helping on the "my Home" but I suspect its more than that as you can't even start a sketch,etc.. which should function 100% independent of the my home stuff unless thats the only way you think you can start a part/iam,etc...
Message 8 of 18
ChrisMitchell01
If you can't even create a sketch in a new part then it could be graphics related. Have you updated/changed your graphics driver recently ? Try going to Tools, App Options, hardware tab & change to Software Graphics.
What graphics h/w do you have in place ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 9 of 18
mcgyvr
Chris
Yeah thats where I was going to go too...
Not sure if you caught the part about "can't create a sketch".. so that was just a friendly heads up..
Message 10 of 18
Hi Chris,
I changed to Software Graphics and now it seems to work 🙂
many thanks for the help Chris, highly appreciated.
Best regards
Morten
Message 11 of 18
mcgyvr
@Anonymous wrote:
Hi Chris,
Best regards
Morten
@Anonymous You don't want to do that as the solution..
Its like driving a car with an anchor hanging off the back...
You want to update your graphics card driver so that you can get off software graphics..
Software graphics will cause Inventor to be slower.. Its essentially a "diagnostic" tool to use to see if your graphics card/driver is causing the issues or worst case for those that have a computer thats vastly insufficient and work at a company were spending $100 to increase performance is absolutely out of the question.. (so basically a dying/dead company).. Don't be that guy..Smiley Very Happy
Get that driver updated.. or buy a proper graphics card..(but I think an updated driver is all thats needed)
If you post your graphics card type (brand/model) we can tell you what driver you should be using.. Or just head over to the card manufacturers site and load the latest driver..
Message 12 of 18
Hi
I am not very good with finding these things on the computer.
I have written below off what I think is the graphic card and computer info
Windows 7 enterprises service pack 1
Processor: Intel(R) Core(TM) i5-4300u-CPU @1.90GHz 2.50GHz
Installed memory (RAM): 8,00 GB
System type: 64 bit operating system
Message 13 of 18
mcgyvr
@Anonymous wrote:
Hi
@Processor: Intel(R) Core(TM) i5-4300u-CPU @1.90GHz 2.50GHz
@Anonymous
Nope... No graphics stuff there..
Do this..
http://www.enki-village.com/how-to-find-out-your-graphics-card-windows-7.html
Message 14 of 18
See ATT. of what I got.
It dosen't tell me much
Brg.
Morten
Message 15 of 18
mcgyvr
Brg.
Morten
@Anonymous You need to go to the "Display Tab" not the first system tab.. There it should show the correct information..
Per step 4 of that link I posted..
For graphics card information, switch the tab to "Display" to check.
Message 16 of 18
See ATT.
Morten
Message 17 of 18
mcgyvr
@Anonymous wrote:
See ATT.
Morten
OK yeah your computer is basically inferior for Inventor so I would suggest trying the "Conservative" setting on tools..application options..hardware tab and uncheck "software graphics"... Then restart Inventor and see if everything works now..
If not then turn back on software graphics and suffer even more of a performance loss...
This would be a good excuse to get your company to pony up for a computer that actually meets the hardware/system requirements for the software you are running..
System requirements here..
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Message 18 of 18
Do you think it helps to upgrade to office 2016?
Morten
