I am trying to place a part at a certain angle, but that doesn't work.
Please see the attached files, the part is marked red.
There are two angles, top view (23 °) and aft view (2 °)
Can someone help me?
Solved by JDMather. Go to Solution.
I would use assembly constraints.
i have tried that, but that only works (for me) in one angle.
Whish constaint would you use?
I would use whatever constraints I need to solve the true Design Intent.
It should be rather obvious that this question cannot be definitively answered without access to actual assembly (or portion of assembly in question) and additional information about precise Design Intent.
