I'm using Inventor 2016, I know that is possible to make a rule, that show a Warning Window, for example in my piece I want to show a Warning window if my angle is less than X deg, any body know where can I see a tutorial for this rule?
Thank You.
kelly.young has edited your subject line for clarity: Rule "Warning"
Solved by mcgyvr. Go to Solution.
Solved by YannickEnrico. Go to Solution.
There are many places around the web for iLogic. Autodesk also has some easy-to-follow courses.
I made a brief example, though
If d0>100 MessageBox.Show("Warning: d0>100", "d0 warning") End If
Assuming d2 is your angle parameter
If d2 < 135 MessageBox.Show("Angle Error", "Parameter Monitor", MessageBoxButtons.OK, MessageBoxIcon.Warning) End If
