08:24 AM
In previous releases, I could RMB on a section line, select edit, and then edit a section line in a sketch (which would be attached to the view I was taking the section from). In 2016, I'm finding that this same command brings me to a sketch attached to the base view, but the section line remains in phantom, and cannot be constrained (either by dimensions, or geometric constraints). Even if I could, the "Project Geometry" icon is grayed out, so I can't project anything in the view to constrain the section line to. Is this "working as intended", or should the old functionality be there? Is there some new method of constraining a section line that I'm missing?
