Inventor Forum
Inventor 2015 Presentation Start Assembled End Exploded
2 REPLIES 2
221 Views, 2 Replies
Hi.
Is any way to make a presentation, when the starting position is assembled, and the ending position is disassembled.
I have Autodesk  Inventor 2015.
Thank you.
kelly.young has edited your subject line for clarity: Presentation.
2 REPLIES 2
Mark.Lancaster
Its called a Inventor Presentation file or ipn file type.   If you start a new file and select presentation and select your finished assembly you can start tearing it apart.   I'm in mobile mode and unable to share links.   Also the presentation interface has changed in recent releases and what's in Inventor 2015 is not tyw same in 2017 2018 and 2019.  So if you Google it just make sure the info is for 2015
Mark Lancaster
jhackney1972
I do not have a copy of Inventor 2015 and at some version the presentation interface changed completely, I do not remember.  If Inventor 2015 uses the old interface, there is a switch right at the top of the browser where you could select something like "Show as assembly".  Since I am using Inventor 2018, I cannot show you a screen capture.  If the interface in Inventor 2015 is the same as later versions, this switch is gone.  You have two options at this point.   You can create a video of the presentation and use the "Reverse" check box (see screen capture below) or you can drag the tweaks in the storybook into a reverse order, which is somewhat of a hassle.
I have attached a screencast showing the later.
Screencast will be displayed here after you click Post.
13a6cc45-03cb-42fc-9b8c-b908cf1220c4
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
