Inventor Forum
Inventor 2015 performance
3 REPLIES 3
ravikmb5
665 Views, 3 Replies
Recently we have upgraded to IV2015
Inventor studio and Inventor Dynamic Simulation are too slow
dont know what exactly changed in IV 2015 compared to 2014
in these environments
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
3 REPLIES 3
iancross
in reply to: ravikmb5
Hi Ravikmb5
What is your Graphics card?
double check the compatibility of your graphics card at AutoCAD Graphics Hardware
rule of thumb, Nvidia Quardo or ATI/AMD Fire Pro
8gb ram is a bit low if you are running studio and FEA/dynamic simulation again it all depends on the size and shape and complexity of your models
change your application settings > Hardware to compatibility mode see if that speeds things up.
Empty out your Temp folder c:/users/<<USERNAME>>/appdata/local/temp/
What Antivirus software are you using, they can cause a little issue, Trend micro has been known to cause a few headaches.?
Ian
Ian Cross
www.xcrosstech.com
Vault, Inventor, and MFG Specialist
Across Technology, Across Industry
karthur1
It does make a difference as to your graphics card with 2015. I'm not saying that you need a Quadro card.  I have several workstations here that all use $150 GeForce cards with 2015 and they work fine. We work with some fairly large assemblies. I dont want to get into the quadro/geforce debate.  There is plenty of info on the forum about that.  Look at this benchmarks.
When you say "slow" are you talking hours to do what you are trying to do?  While you are waiting on it to process, start the windows task manager and look at the process.  What percentage CPU usage is the Inventor process?
Kirk
ravikmb5
in reply to: karthur1
i am using Nvidia Quadro 600
i was getting good results in inventor 2014
Recent upgrade to 2015 was the problem
Studio and Dynamic simulation environment is very slow
Ravi Kumar MB,
