Inventor Forum
Inventor 2015 Opening From Vault Will Not Respond Having To Do Daily Repair
5 REPLIES 5
327 Views, 5 Replies
So within in the last 2 months I've started to do a daily repair on my inventor 2015 due to the fact that once I start program and go to open from the vault it won't let me, so I do a repair and it works...any ideas why this is happening?
kelly.young has edited your subject line for clarity: having to do a daily repair
5 REPLIES 5
The_Angry_Elf
With so little information to go on, no.
Could you possibly elaborate a bit more?
You should not have to be doing a repair install on a daily basis just to use the software.
Explain what is happening, take screen shots of the process and any errors, etc.
Are you up to date on all SP's for both softwares?
in reply to: The_Angry_Elf
That is pretty much all I do, open the program and go to open a file from the vault and it will not respond, I'm currently checking for updates to make sure it is good but so far it looks to be updated.
Updates are all current.
Mark.Lancaster
@Anonymous
It almost sounds like you have a dialog off the screen.  When the lock up occurs, do the following..
ALT+SPACEBAR
M key
Left or Right arrow key
Move your mouse..
Does a dialog trap to it..
Mark Lancaster
in reply to: Mark.Lancaster
I will try that next time it happens, thank you
