Inventor 2015 multi-processor capability?
cadman777
Advisor Advisor
cadman777
Can someone please tell me if Inventor 2015 uses multi-processors when doing those dreaded updates to large models that have many inter-relationships?
I may need it for FEA as well.
I don't need it for rendering.
Thanx
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
blair
Currently IPT's only use a single core along with IAM files. You do get multi-cores in the IDW enviroment generating views and in Studio and FEA.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
A programmer told me that multi-threading is a huge deal to implement. So I suppose no sudden changes will come.
sam_m
and the most popular request on Ideastation is....  *drum-roll*....
http://forums.autodesk.com/t5/inventor-ideastation/full-use-of-multicore-processor/idi-p/3744575
As far as I understand, to use multiple processors you need calculations that can be done in parallel.  But, this is almost the opposite of the linear nature of part creation (extrusion 1 -> fillet 1 etc) means you can't calculate a feature down the tree at the same time (or before) the feature above it has been processed.  So, whether it's even possible, no idea.
But, there's a good question whether an assembly could use multiple cores to process each component in parallel (assuming there's not adaptive cross-linking)?
Hopefully something can be added to Inventor sooner than later, as it would be fantastic for pretty much all users.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
cadman777
Thanx!
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
