Inventor 2015 Modeling Wrinkled Paper Bag For 3D Print
Message 1 of 10
I am attempting to create something similar to this:
But cannot get enough wrinkle action. I just need to know how to wrinkle an object properly.
Any ideas? I'm sure this is an easy answer.
Thanks in advance.
kelly.young has edited your subject line for clarity: How do I create this shape?
Replies (9)
Message 2 of 10
Thomas_Savage
Freefrom could be a good way to create that shape.
Especially if you are trying to get all them wrinkles in it.
Thomas.
Thomas Savage
Design Engineer
Message 3 of 10
thanks Thomas
Can i use freeform for inventor 2015? i tried but i cannot get this
Message 4 of 10
Thomas_Savage
I am sure you can get freeform in Inventor 2015.
I have attached a screencast. This shows you how to place freeform on your ribbon.
Which you will then be able to use.
Thomas.
Thomas Savage
Design Engineer
Message 5 of 10
SBix26
In Inventor it is definitely not an easy answer!
Follow @Thomas_Savage's advice if you really want to do this in Inventor.  But Inventor is not particularly suited to this kind of task.  There are lots of other modelers out there that will do a much better/easier job of it.
Sam B
Inventor Professional 2018.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Message 6 of 10
but I cannot modifique this form that i did, how can I modifique this form now?
Message 7 of 10
Thomas_Savage
That's not freeform.
Plus the loft has an error, and a few other errors from what i can see.
I thought you wanted to model the part from scratch.
That's why i suggested freeform.
Plus that is nothing like the picture that you attached.
Thomas.
Thomas Savage
Design Engineer
Message 8 of 10
Sorry, I am beginner in Inventor, what is another software that I can employ export .stl for a 3d printer?
Message 9 of 10
kelly.young
Autodesk Support
Autodesk Support
Greetings @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Looks like you have a good start to the project but are just struggling to get the wrinkle texture with the standard Inventor tools.
Like @Thomas_Savage shared, using freeform tools will get you close but might be a bit tedious and difficult.
You could try using Fusion 360 which has different sets of surface techniques.
If you want to just reproduce the bag sculpture you can use ReCap Photo to scan and create a digital mesh that can be printed easily.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 10 of 10
WHolzwarth
You can't do much with 2015 Freeform, because in 2015 only soild shapes could be handled.
In 2016, you can use a surface as basic shape, and more is possible. But it still isn't like wrinkled paper, and you'll run into problems with attempts on thickening this surface..
I think, 3ds Max will get good results. But learning that is no 2-hours session. Do some googling for "3ds Max wrinkles tutorial", and you can see several samples.
2015 and 2016 IPT attached
Walter Holzwarth
