Inventor 2014 Interactive Tutorials functioning in Autodesk Inventor 2017?
Message 1 of 18
Hi! I´ve a Microsoft Windows 10 Operating System, Chrome as a Web Browser and un Autodesk Inventor 2017 Trial Version and I´ve tried to download Autodesk Inventor 2014 Interactive Tutorials ( Tutorials Data set zip file ) without succeeding. Is it overall possible? In the Instructions is only mentioned the folders to unzip for Windows 7 and Windows 7/8.
Replies (17)
Message 2 of 18
Curtis_Waguespack
Hi pekka.a.keto,
Is there a reason you would not use the 2017 tutorials?
 In Inventor 2017:  Get Started tab > Tutorials. Under Type, select Available Tutorials
I hope this helps.
Curtis
Message 3 of 18
mcgyvr
The dataset is just Inventor files..
There is no reason they cannot be used/opened in 2017..
Not sure what the instructions you are reading state or what the real problem is as you didn't say..
Message 4 of 18
Curtis_Waguespack
Hi mcgyvr,
I'm not sure that would be true for the Interactive Tutorials due to some of the built in "magic", but you might be correct.
I hope this helps.
Curtis
Message 5 of 18
mcgyvr
Hi mcgyvr,
I hope this helps.
Curtis
The datasets zip files are just ipt/iam files..
But yes I don't know why they wouldn't just use all 2017 stuff.. Except looking at it now the 2017 stuff seems to be severely lacking compared to prior versions from what I see..  Just 19 tutorials that don't really apply to basics/learning from the start..
The "learning path" is ok but need to be installed,etc.. which would stop me immediately from going that direction as a new user.. There is NO information presented on how to load the local help,etc..
I'm just presented with an error page with no direction..
Failed to load URL file:///C:/Users/Public/Documents/Autodesk/.desktop-connect/.docstore/guided-tutorial-plugin/INVNTOR/2017/ENU/997634607367217541/Video/Sketches.webm with error The file or directory cannot be found. (-6).
Message 6 of 18
Curtis_Waguespack
Hi mcgyvr,
Oh, I was thinking that the tutorials were more than just the Inventor files. Smiley Embarassed
I found the Guided Tutorial download for 2016:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2...
Can't find the same for 2017. Smiley Frustrated
Maybe @jeanie.wayker can help us locate them, and can get your feedback concerning the 2017 Learning Path to someone who can help.
I hope this helps.
Curtis
Message 7 of 18
Paul.Normand
Hi all,
I had to read this thread from top to bottom to get a handle on what is being discussed. Here's my take on the issues:
Prior to 2017, new users could access the Learning Path tutorials with no download. That hasn't changed in 2017. For additional tutorials, we provided a download site which had a list of self-extracting files with no thumbnails or any info on what you would learn in the tutorial. The old style (pre-2017) tutorials were powered by xml files. In 2017 we switched to json files.
We do have the ability to convert old tutorials you created to the new json format, so please reach out to me if you need help with any conversions. The tutorials that were available on the download site are in the process of being updated and republished in the new format, so there is no need to convert those. If there are some previously available tutorials that are not published yet that you need now, let us know so we can prioritize.
In 2017 we introduced a new delivery system for the guided tutorials along with the new engine. Publicly shared tutorials simply appear in the Available Tutorials area of the gallery the minute they go live, so check back often! There is rich descriptive text when you mouse over an image and you can also search the tutorials in the gallery with keywords. For example, if you search for contour flange, you will see that the command is used in Sheet Metal 3.
And in 2017 R3 that just went live, we turned on the authoring tool!
That means that anyone can now create and share tutorials publicly or privately. The mechanism is very similar to how Screencast works. Click Create Tutorials to begin the process and to view the two how to videos embedded in the tutorial anatomy page that appears. There are also some helpful hints for authors located here:
http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-03AA0761-0FBC-4772-8C09-6AA74C48CAA3
And last but not least, if you can't run the tutorials (i.e. DesktopConnect error), let us know so we can resolve the issue!
Let us know what you think!
Paul
Paul Normand
Principal Content Developer/SME
Design Lifecycle and Simulation (DLS)
Autodesk, Inc.
Message 8 of 18
Curtis_Waguespack
Hi Paul.Normand,
Nice! Wish I had time to create some tutorials with that, maybe the opportunity will present itself in the future.
Thanks for the reply. That clears a few things up for me at least.
I hope this helps.
Curtis
Message 9 of 18
mcgyvr
Paul
@Paul.Normand  "Raises hand smiley"..  Not that I need the tutorials but just reporting what "I" get when I try to access the learning path and how that may be confusing to a new user...
I have not spent a single second trying to investigate... (maybe I needed to check a box during installation or whatever)
I assume the error I posted above is what you meant with the desktop connect error..
Message 10 of 18
Paul.Normand
Thanks for reporting this Mcgyvr. We are checking into the cause and I'll post the solution when we find out what is going on.
Paul Normand
Autodesk, Inc.
Message 11 of 18
cmbronder
Hi McGyvr,
I am concerned that you got that error trying to play the "Get Started with Sketches" video from the Learning Path. When you get a chance, would you please let me know the version of Inventor 2017 you are using?
I do not see this problem with Inventor 2017 R3 that was released November 7, 2016.
Thanks much,
Clare
Message 12 of 18
I know this thread is a bit old but it describes exactly the problem I am having. I have Windows 10, use chrome as a browser, using Inventor 2017 Professional. I am new to Inventor. The Learning Path guided tutorials are fine but only cover the basics. There are only 21 other available tutorials in English. I need access to more advanced tutorials like Tube and Pipe in particular. In Inventor 2017 help these more advanced tutorials are listed in the Tutorial Archive section under the Tutorials button. All these tutorials link to 2014 help. If these guided tutorials are in xml rather than json and won't function in 2017, why are they listed? And more importantly how do I access and use these tutorials because I need to use tube and pipe for my job?
Is there some kind of work around? Please help!
Message 13 of 18
mcgyvr
Good luck.. Good "tutorials" from Autodesk just aren't out there IMO..
And for tube/pipe and cable/harness your offerings are slim to none..
You might want to check out youtube or contact your Autodesk reseller to see if they offer classes,etc...
The 2014 stuff is probably the best you are going to get.. and thats not saying much..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-C68BB356-A00F-4775-9913-9D429DDD690E-htm.html
You can get the datasets here.. Which you can open in 2017 just fine and follow along with the help page link I just posted..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/ENU/123112/files/inventor-2014-tutorials-html.html
I "think" Autodesk expected users would populate the "tutorials" for them or something.. Paul seems to be trying but...... well.. one man show and all just isn't cutting it..
Message 14 of 18
Paul.Normand
Greetings.
The reason we have a link to the 2014 tutorials is because not all tutorials have been converted to the new guided tutorial format and the information they contain is still helpful.
The old tutorials consist of text and images on a web page and a downloaded dataset. They are not interactive and do not run in-product (do not use xml or jsom files and run in a panel).
Tube and pipe and many of the unconverted ones are in the backlog for conversion. Sounds like Cable & Harness and Tube & Pipe should be moved to the top of the To Do list.
Paul
Paul Normand
Autodesk, Inc.
Message 15 of 18
mcgyvr
Greetings.
Paul
Don't let my rants move priorities around.. I don't use the tutorials at all..
But I'm sure colemondean might like it.. (probably too late now though)
The "tutorials" I used were back in Inv8 or something and were an actual printed book.. Oh books... I miss you so 😉
Message 16 of 18
Thanks for your reply,
I feel a bit foolish now. I started with the data set download page and after downloading I kept looking for the tutorials to be available in the tutorials window. If I would have paid a little more attention while in 2014 help and clicked one page down it would have been obvious how they worked.
Derp.
Message 17 of 18
WHolzwarth
That's it. If anyone can create lots of Guided Tutorials, quality will go down the river.
I've liked the former tutorials, available in 2015 and earlier versions.
2015 type tutorials can still be accessed, after some settings.
Walter Holzwarth
Message 18 of 18
mcgyvr
Oh the book was full of errors too... and really lacked any "advanced" functionality... But it was enough to get me limping down the road on my own..
There are still things in c&h that I have no idea how to properly do..
