Inventor 2014 - How to refresh after free move?
bobc
Message 1 of 9
bobc
The Inventor doc says "The part remains in the moved location but snaps back to its constrained or joined position when you apply a new relationship or update or refresh the assembly."
How do you "refresh the assembly"?
The situation is, I've move some parts, decided not to add a constraint, I'd like the parts to snap back but I'm not seeing a refresh command. Googling and searching this forum didn't help.
I don't want to close/open the assembly - surely there's a simple solution?
Bob
--Bob
AutoDesk PDS 2014
Windows8 64bit / Asus P9X79 / i7 3820 / 32GB RAM / 256 GB SSD / nVidia K2000D / Dual 27" LCD
Replies (8)
Message 2 of 9
blair
Most likely the item in question still has some constraints applied to it, that's bringing it back to it's starting position. It might also be an Adaptive part as well. I think that the "Move" function was added back in 2014 (in the constraints box), if you select it and move the part, you will see small "bands" from the part to other parts, that show related Constraints.
You would also be able to see Constraints on the part in the Browser Window.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 9
bobc
Sorry, but I think you missed my point.
I have moved the parts (yes, rubber bands)  now I want the parts to "SNAP" back to their home positions.
A close/open of the assembly snaps them back, or adding a constraint snaps them back. But the doc says you can snap them back by "refreshing the assembly".
How to "refresh the assembly" is the question I need answered.
I do appreciate your help.
Bob.
--Bob
AutoDesk PDS 2014
Message 4 of 9
blair
The "Rebuild All, will refresh the IAM, the little yellow arrow icon on the very top of the menu bar.
Delta Tau Chi ΔΤΧ
Message 5 of 9
PaulMunford
They will only snap back if you've applied a constraint. The Free Move command temporarily overrides constraints. The constraints Will re-assert themselves on refresh.
Does that make sense?
Paul Munford
Technical Onboarding Architect
Linkedin
Message 6 of 9
bobc
That's what I was looking for!
It's located at Manage tab | Update panel | Rebuild All.
Thanks Blair.
Bob
--Bob
AutoDesk PDS 2014
Message 7 of 9
SBix26
No need to use Rebuild All-- just use the Update button on the Quick Access Toolbar (or on the Manage > Update tab): Update Button.png.  It lights up as soon as you Free Move or Free Rotate something.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Message 8 of 9
blair
Thanks, I was away from Inventor and new it was a lightening bolt.
Delta Tau Chi ΔΤΧ
Message 9 of 9
bobc
Sam B
Vault Basic 2016
Thanks Sam, I found it. Works great.
Bob
--Bob
AutoDesk PDS 2014
