I have a problem with only some parts.
Bump is not showing. Tryed all i can think of, but nothing helps.
Bump is not showing, when i use "Shaded" or "Shaded with edges".
But it shows if i use Raytrace.
Any got a solution?
See pictures.
Kind regards
Henrik Graversen
Henrik,
Can you also post an actual ipt file with the problem ?
Chris
I could see the bump, when moving EOP down from the top.
But when I reached Hole2, the bump disappeared. I can cycle that back and forth.
And if I change the hole type to non-threaded, bump is ok.
Same behavior occurs already with Hole1, but I've overlooked it. Extrusion4 behind Hole1 brings the bump back again.
Walter
Walter Holzwarth
Hello Henrik,
I tried to to reproduce this issue on Inventor 2013. Its wrong behaviour.
I am confirming it and I will work with developer to solve this issue.
Actually thread is a bad guy here. Some how intventor disables bumps when thread will be applied to sheetmetal part.
There is a workaround for you in this case.
Simply move "Cut 3" in browser below "Hole 3". It will bring back bumps.
Let me know if more help is needed.
Thank you,
Maulik Patel
I am sorry.I was logged with different account.
Thank you,
Maulik Patel
