Hi!
You have to change the filter:The filter in assembly enviroment is defined by default as "Select Priority Component" and therefore, Now you are selecting all sub-assembly as one "occurrence".
Change the selection filter to " Select Part Priority": This way you can select any parts placed in a sub-assembly directely from the main assembly...
... so:
- Change the filter (is easy, check the image below)
- Selectthe part
- Uncheck visibility as a normal main assembly part.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
CCarreiras
