Inventor Forum
Inventor 2012 and Excel 2010
13 REPLIES 13
Message 1 of 14
2198 Views, 13 Replies
I am having trouble "edit via spreadsheet" from an iPart table within Inventor 2012.
I am using Excel 2010, but when I select "edit via spreadsheet", Inventor loacks up as if it is trying to start excel, but doesn't. If I push "esc" it comes back to operational but still no spreadsheet.
Anyone else having this problem? Anyone know why this could be?
Have tried uninstalling excel and reinstalling. My next step is to reinstall Inventor if no one can help.
13 REPLIES 13
Message 2 of 14
alessandro.gasso
Hi Jarrod,
Please, try the solution http://usa.autodesk.com/getdoc/id=TS14079866
I hope it helps.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Message 3 of 14
in reply to: alessandro.gasso
Thanks Alessandro. This has resolved my problem.
Message 4 of 14
I tried to find the registry key file listed in the fix but could not find it.
Is there a more 'current' solution?
Not being able t use iParts is very frustrating.
Please help.
BR,
Michael
Message 5 of 14
PACDrafting
what version of windows are you running?
Message 6 of 14
PACDrafting
in reply to: PACDrafting
Message 7 of 14
Windows 7
Message 8 of 14
I do not have the file listed in my registry key.Smiley Frustrated
Message 9 of 14
PACDrafting
Is it 64 bit or 32 bit?
If 32 bit. The folder structure is different.
Instead of it being located in the " wow6432node" folder. It will be under the " software\autodesk....etc folder
Message 10 of 14
it's a 64 bit machine. thanks for the prompt reply!
Message 11 of 14
I'm having the same issue with Windows 7 64 bit. I went to the site with the fix and I tried to play the video, but the video does NOT play. I tried playing the video from 3 different browsers but it still will not play.
Dan
Message 12 of 14
PACDrafting
Keep trying. You need to watch the video!
Message 13 of 14
I am also not able to see the video. I'm running Windows 7 64-bit and tried Firefox and IE9.
Does anyone have written instructions that cover the video?
Message 14 of 14
I have the same problem and the video will not work for me either.  Can someone please post detailed step by step instructions on how to fix it?
Scott
