Inventor 2010 stl file export
Hello
Is there any change to make the stl file resolution better than "Fine" in Inventor 2010?
Thanks for your help
Chris
JDMather
You have always been able to set the resolution through the registry - I think there is a add-in at mcadforums to make it easier.
This is the 2011 Options dialog.  Note the custom button.
Note also the option to output as binary (there has also been an addi-in for this for some time) to make the files significantly smaller.
There I found a solution to this
Have an nice day
